Sigma 50/1.4 Art
Caporegime
20 Oct 2002
Wish i was in a Ramen Shop Counter
It's here !!! Who else is getting one ?
I still like my current Sigma 50mm. I was going to sell it after getting the Sigma 35mm but I prefer the 50mm focal length especially when outside. I'll pick one up eventually once the price has settled down.
Highly doubt I'll bother tbh. Its a nice lens but a very marmite focal length.
I am not sure marmite is the right word, that can apply to every lens. Not every lens is loved by everyone. But I know what you are saying, I spent the last 2 weeks in Hong Kong with just the 50mm, although i have shot some nice images, I have found the 50mm quite a challenging lens to work with. May be because I am used to the 35mm so especially at the beginning I wanted to step back a lot. It got better towards the end for sure, so I agree to a point that 50mm may not be for everyone.
There are however times I prefer the 50mm over 35, like table decor shots.
I would if I was intending to stay on crop and I have thought about it but on FF I wouldn't find much use for it. It's huge though 17-55 2.8 size. Kind of changes the idea of carrying a light prime or two :D
The lens needs MA, +9 on one 5D, +14 on the other.
Will do it to the lens itself when I get the dock tomorrow.
First impression are that it has low CA, nice bokeh, build quality is very good.
The hood however is not as nice.
I had the same issue going the other way. I was used to shooting the 50mm so much that it took a while to get used to the 35mm. I still haven't really!
It's one of the reasons of the single lens trips, so I get to know the lens, learn about the lens, the focal length. It's good to work with all of them, if say one of them break at a job then you need to work with another focal length, you need to be at your best that you can at that too.
Yeah I've left the 50 in the bag since I got the 35 to force me to use it and get used to it.
Not sure i could justify nearly £900 on this over the Nikon 50mm f/1.8 i have. I'm sure the Sigma is great but i'd rather spend the money on an 85 or 24-35mm prime
£780, after tax and duty.
And I do understand, hence i've got L for everything else except the 50mm. Still don't have 50L, perhaps I'll put an red elastic band on it :D
It's a new optical design. The 50L although is a 2006 lens, its design is based on their older 50/1.0 lens and that is based on something from the 80's. The Canon 50/1.4 and Sigma's old 50/1.4 have a similar design. This new design, similar to the Otus produces better images.
