Just refer my TJ build to be honest. This isn't finished yet though so I need to get it done and keep at it.
Yer, I can see black end caps fitting in better, another thing do Bitspower do tinted tops for the ram blocks? that might fit better also.
Looking forward to more photos!
I thought of black ones for the ram but now I have some colour in the fluid it looks good.
They don't do the ice black ram tops like the CPU.
Finally made a Break through. How goes your TJ?
Still running with no leaks so looking good, got some extra cable so I can make up the last pci-e cable tomorrow, Think I may drain and refill tomorrow. See if I cant get it finished then
Those Bitspower blocks do look nice though, just a bit of a pain to get a hold of it seems.
Yep - got to go to our friends in Florida or the Netherlands
Looking forward to seeing your build mate- good luck with it!
Purple! Even though it isn't there...
Perfect Paul - sweet job as always
Black end caps look a lot better
