I'm getting purple and sometimes black lines when playing Dark Souls 2 on my 290. Anybody else got this problem? I'm thinking it may be a driver issue.
Your not having a lot of luck with that card are you
Set the Memory to 1250Mhz?
I got one refunded and I was testing the other one over weekend. It seems okay in some games but in DS2 I get weird lines.
Which is the default one?
Well I must say I cant tell the difference in frame rate etc from using that Tri-X 290X and this Vapor-X 290.
I pulled one card out, fitted the other and its as if they could be the same card, lovely.
Always a good sign.
I presume you're using crossfire now though?
It happens on Nvidia/AMD,try setting anisotropic filtering set to medium.I hear that gets rid of the problem.
Will be getting another Gigabyte 290, by the looks of the power draw on corsair link, i may just have enough power on the 860i to power another, it will be border line though, the chart is from BF4 under full load.
380 Watts total system power, take off the CPU, fans, water pump ecte... the GPU is probably using <300 Watts, if that. i could easily run 2 on my XFX 750. You have plenty of room.![]()
, next is to sneak another 290 in whilst the Mrs is up town shopping one day
I'm having trouble putting a good overclock on this card. As soon as I stick +200mV through it my screen starts going all distorted. Can the VRMs not handle the volts or something?
