What are the currant differences between Nvidia and AMD graphics cards
29 Dec 2012
I know both will have some good cards but is there anything one does that the other does not ?
Currant? You're too slow for Good Friday hot cross buns!! :)
BTW is there really any need for the multiple topics you're posting? Perhaps consolidate your questions and ask in a single thread. Likely to be more structured and beneficial for yourself that way.
None. And if you plan to keep that AMD FX, buying a AMD card makes more sense, since you can use Mantle on the games that support it or going to.
After that, they are both the same.
There are only a few differences^^ look at the thread thats been linked
Mantle while good only helps if the game supports it otherwise its useless
@OP, If you're planning to buy a new card you may want to wait a bit as AMD cards are due a price drop back to normality now the mining crazy is dead and done.
Don't listen to these n00bs :D , i'll give you the honest answer , Nvidia cards have a mainly green logo, Amd radeon cards have a mainly red and black logo. Whats more important than the cards are the respective fanboys, both will defend the indefensible , see dark where there is light and light where there is dark.
Other than each others 'features' which unless you use 3d (nvidia) or use a 3 monitor setup (works best with Amd eyefinity) both will display graphics on a monitor at varying levels of performance.
Dont listen to anyone blab about phyxs (nvidia and not massivly supported) or mantle (Amd and runs on 2 whole games and a really bad benchmark) neither are worth one over the other right now.
Read some reviews, dig through some feedback on forums and buy the best you can afford.
Thanks, thats very useful information for me, i was going to see what's the best vard i can get for my budget
