Probably, any more than quad core is overkill for general use and these CPU's are aimed primarily at OEM's hence the onboard GPU.
4.4ghz boost is great, makes it almost pointless overclocking... But where's the fun in that aye?
There are no documents anywhere that state it will or wont run on Z87 or they are for Z97 only, after all they are still 4th Gen chips.
when did they remove the loophole from b85? far as I know b85/h81/87 allow oc of k chips
only due to a blunder
far as I know they can only block it through a bios update that's down to board makers to implement or not
