LG to Introduce 34-inch IPS 21:9 UltraWide (Model UM95) monitor
Hmm so all should be ok then. Some guys on other forums were saying how their single 780 TI wasn't capable of keeping the framerates up in games. I can';t see the jump from 2560 to 3440 (27" 1440P) being that huge to cause a massive drop in fps. Certainly 1440P hasn't shown signs of being stressed on my GTX780 (non Ti).
It has 33% more pixels than standard 1440p, so AA is deffo off the cards for any single card solution.
Single GTX 780 Ti is not enough @ 2560x1080 I can confirm so higher will be slower. Lot more pixels to render/manipulate etc etc
Interesting, what games? I've not got BF4 but certainly BF3 and other games (Batman, Grid 2, Tomb Raider, Bioshock DLCs, Metro Last Light etc) had no problems with being maxed out. Edit* With varying levels of FSAA, some games I use FSAA, some not as they're not needed I find. Games like TF2, yes, slap on 4x/8x as well as on Grid 2 but BF3/Bioshock and others like that I found no need.
Think I might have mentioned this before in this thread, or some other, but I have 2 x 780Ti, and even this isn't enough to run ALL games at MAX settings and never dip below 60fps, which is the minimum holy grail.
And this is on the little brother of the new big boy ie I have a Dell 2560 x 1080.
In preparation for possibly upgrading to a 3440 x 1440 screen I've also been playing with downsampling and created a custom res of 3440 x 1440 for my screen. It's definitely more punishing, and the maths bear it out - 30 to 40% more punishing.
For the games mrk mentioned - most of those might be ok on one 780 at 3440 x 1440 ie Batman, Grid 2 and Bioshock, but Tombraider (especially with DickFX hair) and Metro LL won't be ok maxed out.
Whoah hold on a second, I don't want to be seeing DickFX hair if it can be helped!
On a more serious note though, I've got the new Wolfenstein on pre order and will likely get Watch Dogs too so if those games run well at the higher settings then I'll keep the 780 as is else I will probably ably look toward a dual gpu single card solution as my mobo drops to 8x per lane if I install a 2nd card.
DickFX. Think I should trademark it? :D
My motherboard drops to 8x 8x with 2 Ti's. I would not worry about that one jot sir. From what I remember running 8x 8x has a teeny tiny impact with dual cards compared to 16x 16x.
Just get another 780 now, you know you will soon ;)
I guess I'm still bummed by used 780 prices considering I paid full retail when this was new such a short time ago!
I guess I'll do that :p
Maxxed out with FXAA + Vsync:
Crysis3
Shadow Warrior 2013
NFS Most Wanted (Criterion)
NFS Rivals
Metro LL + PhysX
Batman Arkham Origins
All I found struggled badly in many places on a single 3GB GTX 780 Ti. At least they supported 21:9 though that more than anything was the biggest issue along with poor Win 7 ClearType tuner issues.
Yeah, Crysis 3 isn't playable on a single 780 at 3440x1440. I've got a 780 SLI setup and it runs fine with the second GPU enabled, though still nowhere near a locked 60. That game is just insanely demanding.
If you are willing to drop down a few settings on Metro and Batman they'll run fine and still look great, PhysX is a big resource hog in those titles.
That's surprising, do the extra horizontal pixels make that much of a difference? I only ask that as I can run Crysis 3 on full settings (bar a slight decrease in AA) and it runs sweet as a nut at 2560x1440.
Definitely considering this upgrade to the 34UM95 though, looks an outstanding monitor :)
Woops, should have mentioned my card is a 770OC edition!
Box
Huge. Way bigger than I was expecting. Mine didn't come wrapped in padding on the outside like some other folks did in the USA though, just wrapped in white plastic on the outside then the box.
Accessories
I got a HDMI lead and Displayport but since I recently bought one and already had it wired up I never unwrapped the bundled cables.
The stand is actually metal, the only plastic bit is the trim panel parts along the top. It's quite heavy too. In videos and pics I've seen online it looks plastic. I threw that back in the box because I wasn't going to use it.
^The VESA mounting area comes with a protective sticker that you place over the casing and then mount the desk arm plate on to. Protects the case from scratches, a nice touch I thought.
The screen
It's huge. bigger than I thought it would be in fact and it's heavy. It comes with a little energy star sticker on the bottom glossy plastic bezel bit (the only bit of bezel on the front really) and as I peeled it off it left a residue. I started to wipe off the residue and noticed that the glossy black plastic area was becoming marred/cobwebbed like black plastic does once it ages. I hate that and it's a shame.
Picture of that area below:
Why give you a protective sticker for the VESA mount and then put a sticker on the bezel which leaves residue? Kind of a half-assed oversight in my books. I'll end up brushing the whole strip so it's matte instead of glossy in time though so it won't be an issue again.
^I also noticed the LG logo isn't exactly in the middle in line with the power LED and joystick button, minor nitpick and most people wouldn't even care, I don't either but this is the kind of thing I tend to notice on stuff generally :p
I really like the rear facing connection ports too. I have always hated the ports facing downwards and this is just nice and it all works especially as I am using a monitor arm.
^The amount of AG coating is lower than on the Dell U2713HM I had. It's not glossy but it's not matte enough to cause snow on solid light colours. The U2713HM was an improvement over previous Dell screens (U2412M which I also had) in terms of AG coating
On my desk it's 2 inches shorter than my mousing surface, the Boogiebug XL - That will give some of you an idea of how much desk width this thing takes up!
The button and OSD
Only 1 button and it's a directional pad joystick thing which I found works really well. It's nice to see you can turn off the power LED too.
Out of the box colours
To my eyes they looked quite warm. I then went into the OSD and noticed the colour was set to custom and each slider was set to 50% for R G and B.
^I plugged in the i1 Display colorimeter and loaded up the LG True Color Finder software. It remains in the system tray and will periodically check to see the monitor is still there to send data to post calibration. This is useful and I'll go into that later.
^I ran a calibration using user specified settings. The software is quite similar to other calibration software but doesn't really go into any deep detail with reporting or trends like Lacie Blue Eye Pro or even Xrite's/Datacolor's own software, no big deal, This monitor has it's own LUT built in and the LG software plugs into that. You specify your desired colour temp, luminance and a few other bits and hit calibrate. The monitor locks out the OSD during this and enables the "Calibration" mode in the OSD (it only becomes selectable once you install the LG software and run a calibration).
What this mode does is locks the OSD settings for brightness and colour and the LG software sitting in the system tray will keep an eye on this and restore if needed. I noticed that the software also creates an icc profile in Windows and assigns it to the screen and disabling it in Windows made no visual difference to the calibration which is expected since the monitor has had the correct settings sent to it directly. I guess the icc profile is applied anyway for those gfx cards/systems not supporting monitor control.
Calibration took about 7 minutes.
Usage
I've now changed my workflow in Lightroom and Photoshop a bit as the extra resolution on the wide end means I can mimic dual screens on this one screen and then some. Start menu has gone to the left and my Lightroom/Photoshop layout look one of a few ways depending on what I'm processing:
Gaming
^Grid 2 max everything, perfect fps with vsync on is locked at 50fps for some reason, seems that game or some games will select a fixed refresh rate, in this case 50 when vsync is in use. Vsync off I get 120fps. TF2 gets 150-200~ fps max everything with 4xmsaa even in heated battles on a full server. Recording in Fraps at half res (1720x720) was perfect, was recording TF2 battles with the game running at 120fps.
My system is a 3770K @ 4.6GHz, 16GB 1600MHz RAM and a single GTX 780.
So far those are the games I've played, been toying with the screen all other times though and I am very very impressed. I have Wolfenstein on pre-order so looking forward to seeing how that runs on this as well as the new Doom 4 beta which comes with it :cool:
^ I then fired up the PS3 (I like to play when I feel like a break from photo editing sometimes :p) and at 16:9 I set the OSD aspect ratio to "Original" - Setting it to 1:1 puts a tiny screen with black boxes around all fours. In Original it's like picture 1 above. Setting the aspect ratio to one of the cinema modes it pans and zooms in to fill the screen and to the most extent for some games this is just fine where you don't need to see the top and bottom margins.
In either instance of gaming I found no problem with mouse lag. I set the OSD to "High" response time as in Windows I found the Low setting caused too much mouse trailing while the Medium setting was better but High just felt the best. I found no issues with motion though I have been gaming on IPS screens since the Dell 2000FPW days.
Movies & TV
^This is where 21:9 shines. I fired up Tears of Steel which is in 2160P (well, 4096x1714) and it was glorious. So sharp and looked so good. I then played some 1080P movies which were equally impressive. Not quite as sharp but still highly detailed.
TV shows are pretty much exclusively 16:9 so you get windowboxes either side. Not much you can do about that but the good thing is that even still the screen area it takes up is still the same size as a 27" 1440P monitor.
Some movies are 16:9 but letterboxed, those you can zoom in to fill the monitor without losing much (if any) content. You need a media player that allows this though. I know MPC-BE/HC does (numpad buttons).
Pros & Cons
+ Cinematic immersion, amazing for movies & supported PC gaming.
+ Uniform colours with no visible backlight bleed (not to be confused with IPS tinge which there is).
+ Gaming performance for me was just fine. I have never gamed on a 120Hz monitor but my gaming style in FPSes has adapted to the nature of IPS and I have no problem at staying in the top area of scoreboards in online FPS games like TF2.
+ The joystick button is genius, so easy to use and nice.
+ Visibly frameless front apart from the glossy bezel part at the bottom.
+ Can have a large browser window open AND a 1080P video beside it and you can enjoy both at the same time.
+ Hardware calibration means whatever you connect up via the other inputs you will benefit from the calibrated colours too.
+ Does not generate much heat. It's been on several hours and it's cooler than my U2713HM. I would say this is mostly down to the fact that this has a power brick so a lot of heat stays away from inside the monitor. The WLED backlight generates little to no heat.
- Glossy strip at the bottom of the screen is pointless and will only look poor over time as you wipe it. I've learnt this out already!
- Reader mode will disable Calibration mode but when you turn Reader mode off it won't turn Calibration mode back on.
- Enabling DisplayPort 1.2 in the OSD did cause random flickering for me even on the Windows desktop. Disabling it solved it. Visually I can't tell any different so maybe 1.2 mode isn't fully working yet I don't know. many others are reporting the same. Let's see if LG release a firmware update.
- Hardware LUT only usable via the LG software. True Color Finder stays running in the system tray. It uses 18MB of RAM only.
- No USB3 upstream cable supplied. I had to use my own.
- Only 1 USB3 downstream port, the other 2 are USB2 ports.
Will I miss dual screen? Yes and no. Yes because I liked having a 24" in vertical orientation and reading sites and magazines as they're supposed to. No because this looks way nicer and offers much more everywhere else.
Should someone else buy the LG instead of waiting for the Dell version? Interesting question. LG have marketed this display at image and video professionals/enthusiasts and the included hardware features benefit them clearly. I have a feeling Dell may not include some of those features in their version and we can definitely expect to see a higher price (I paid £830 for the LG). One thing is for certain, Dell's stands and RMA processes can't be beat.
I'll remain happy with the 34UM95 as long as nothing breaks on it and LG update us with a firmware to fix the DisplayPort 1.2 flicker :)
Additional pics + Video
Damn Robbie you make it look so good that I want one and I am already using mine right now!
I left the energy star sticker on mine and will do so.
Could you tell us how yours calibrated? What was the pre and post calibration settings and results?
Unfortunately I don't think I can as I didn't realise the nature of monitor LUT until after the fact :o
The LG software does have a before/after thing at the end but you only see that after a calibration has finished and since it saves the settings to the monitor directly I don't know what other settings have been adjusted to get the calibrated result.
All I can say is what I remember seeing, that the colour was warm out of the box and that was largely due to all the RGB sliders being set at 50%. I don't know what the factory calibration chart that comes with it is for in this case because the result on the chart was for D65, the colours I was seeing out of the box certainly were not D65!
Post calibration though it was virtually dead on D65 and my desired luminance. (7th pic above).
damn you mrk, you make the screen look so good! :)
i ordered the 32" benq, wonder how this LG would do with a OCed GTX680 (can't be arsed with 780 anymore, will wait for the next generation)
Great review! In the third picture the AG coating looks quite grainy. Is that a true representation or a trick of the light?
Some really nice photographs within the photographs by the way.
Woah, awesome review, now I can't wait for mine. The monitor looks fantastic. I have the same mounting arm, so it's good to see that it'll fit.
LG better fix DP 1.2, I think that is what is limiting you to 50Hz in some instances.
A trick of the light and macro focus combined.
Bravo mrk i loved it apart from no DP 1.2 in the options can we still get 10bit color then with 1.2 disabled? There is no way i would be keeping it until Gibbo could get on the phone with LG for us and find out if there is going to be a firmware update.
Infact a firmware update makes sense to fix this and get DP 1.2a and freesync certification which is all this was lacking anyways. Other than that the review sold me on this TF2 and the 4K movie look glorious.
Bravo mrk but we still have a serious problem as you only get 10bit from DP 1.2 enabled so basically with the flickering and 50hz you are at 8bit with that turned off.
That's incorrect. This panel uses 8-bit + FRC regardless of the signal. And 50Hz, 60Hz or any other refresh rate has no effect on the backlight and does not induce flickering.
Thanks mrk, great review and pics there!
You've not helped in my delusion that I don't in fact want to upgrade my 'mini' Dell 21:9 to a big 'un. Damn you :D
The displayport issue and the game you mentioned being locked at 50fps with vsync on sounds worrying. I've never come across a single game that's capped at 50. 60 yes. There was a user review on hardforum that mentioned being locked at 48 due to a displayport issue was there not?
Can you run a few more games, making sure you use vsync, and tell us what frame rate they're at?
