I just dont understand why no one is offering glass and gloss? It looks amazing at night the colors and defninition is incredible without AG and matte. And it is easy to clean as well. Not to mention the increased percieved contrast levels.
Weirdly enough, it doesn't seem like there are that many DP1.2 supporting cables out there.
I found this one from Amazon. Link
They have a higher bandwidth than regular DP 1.1.
But the one you've linked doesn't mention that - I'm sure realistically there's no physical difference unless one cable has additional pins or thicker gauge or something?
Tip, go into the OSD>Settings>DisplayPort 1.2>Enabled.
Mine was Disabled by default so even though the DisplayPort cable was working I wasn't getting 10bit colour 3440X1440 60Hz
I also disabled the energy saving feature.
Anyone played with the Response Time settings at all?
I just read on a page that doing this locked the display to 48hz? Can someone confirm this is not the case as to why it flickers? Do you get 60hz with DP 1.2 enabled in osd?
We expect pictures a nice lengthy user review and also more pictures![]()
The DP 1.2 signal attenuates very quickly. The maximum DP 1.2 cable length is 3 metres.
Single GTX 780 Ti is not enough @ 2560x1080 I can confirm so higher will be slower. Lot more pixels to render/manipulate etc etcI'll test out everything I can later tonight once I've had a good old play and watched some 21:9 content and had a gaming session
Hmm so all should be ok then. Some guys on other forums were saying how their single 780 TI wasn't capable of keeping the framerates up in games. I can';t see the jump from 2560 to 3440 (27" 1440P) being that huge to cause a massive drop in fps. Certainly 1440P hasn't shown signs of being stressed on my GTX780 (non Ti).
