Great pics mrk - the monitor does look stunning, especially on the arm.
I'm going keep my U2711 till the OLED's arrive though. This is too rich for me for what it is.
1) My monitor's 5 y old - still going strong but until this LG totally dies I wouldn't buy any monitor to upgrade ( will go to projector next )
2) Again I don't have the GPU grunt to run a 4K monitor nor am I massive gamer. Therefore for me consuming movies in 21:9 is what I am excited about
3) Fingers crossed my 7870 2GB will run it. If not might buy a 270x and crossfire or buy a 2nd hand 280x but as you mentioned -already spent a small fortune on monitor.
Surely the main advantage of higher resolution IS in day to day windows use, not gaming... so cannot fathom why you wouldn't want the huge difference in vertical res that 4k brings?
Regarding my 285GTX... I was moreso wondering if it can actually drive a high enough resolution and work considering it only has DVI/VGA... lol.![]()
Wonder how long it would take for an OLED 21:9 though.![]()
Unless an OLED screen is 21:9 and 1440p pixels high minimum then I'm going to find it pretty hard to upgrade to one now lol.
I mean just look how good movies look even though they're 1080P Blu-ray of various mastering qualities!
Nice pics but BTTF1 + Aliens are stretched though they are not 2.35.1 aspect ratio movies so you zoomed in or stretched to fit 21:9Unless an OLED screen is 21:9 and 1440p pixels high minimum then I'm going to find it pretty hard to upgrade to one now lol.
Also I can definitely confirm flickering is still there with DisplayPort 1.2 enabled BUT ONLY within the first 30 minutes of turning the screen on. Doesn't matter if it's a cold power up or warm one, if you turn it off then on it may flicker once or twice within the first 30mins. After that point there are no more flickers. Really a none issue now I'd say.
The whole point is that the current 4K screens (those gaming orientated ones at 29" and so on) are too small to be useful at 4K. Sure movies and gaming may well benefit but for everything else text will appear smaller, icons will be smaller and so on. The pixel pitch is almost perfect on something like a 1440P 27" screen so resolution needs t scale proportionately with pixel pitch in order to keep that nice balance of usefulness and high resolution. The UM95 has that nice balance. If it were 4K it may well have lost that and as mentioned, for 4K to be useful in a desktop setting we're looking at +34" really.
but Pulp Fiction does look good as its native 21:9 almost being 2.35.1
Mrk what backlight have you got, and a really nooby question why do you need one?
Also what software have you got to watch blueray on your pc?
