Sorry, I only just got round to reading your reply. Cheers for the suggestions - I'm going to do some digging and see which of those options suits best budget wise. I don't have a mixamp btw - but am looking into that too now
Ta.
A MIXAMP should last you a lifetime so it's worth the investment.
I'm no audiophile, I'm not fussed on spending hundreds of pounds on the best headphones for ultimate sound quality or bodging together a setup. IMO, any headphones are better than no headphones.
I've had the Turtle Beach PX3's for quite a while and they do a very good job. Wireless, work on PS3, 360, PS4 and PC, very handy. Battery lasts for 10+hours too. You can buy them for less than £50 new.
The PS4 setup is exactly the same as the 360 setup e.g. cable from controller to headset, so still wireless.
The audio from the controller is horrible, it's limited by a crappy bluetooth codec/version as well as stereo, you would be better off connecting to your TV than the controller for Sound Quality, it is that bad. Good enough for voice comms but not for game sound.
Also you don't need to spend hundreds:
2nd Hand MIXAMP = £60-£80
Koss KSC75 = £10
DX Clip on MIC = £1.56
that's £70 for a setup which can be upgraded over time, etc. It will also blow any £70-150 all in one setup out the water. Don't be fooled by the cheap pricing of the mic/headphones, they are really good quality for the money and unbelievable value.
I did this myself, I went from HTF600 to HD 595's and now I have Fidelio X1's in the post, I upgraded the headphones as I saw fit to do so.
Koss KSC75 - £10
Creative Aurvana Live, HD 595(2nd hand), AD700 (2nd hand) - £50 to £75
Beyerdynamic DT770 - £120
Fidelio X1, HD 598 - £150 to £175
AKG Q701 - £200
I don't think you need to go any higher than that and those listed are the best ones for those budgets, in fact the AD700 is arguably the best out of all of them (for gaming only) and is in the 2nd tier, it is crap for music/movies though.
So the best setup in the world can be achieved for as little as £140
The most convenient setup (Fidelio X1 and V Moda Boom Pro) which can also be used for music/movies costs £250
The bang for your buck setup though as I stated above has to be Koss KSC75, Clip On and a MIXAMP (2nd hand) for £70-£80
