the new gpu (1000 core on gpu-z)
https://www.dropbox.com/sh/382a8x5tsc6r2cz/AABu3I0ZTWXk5XvVFIDKJ43aa/new gpu.rom
my older gpu (900 core on gpu-z)
https://www.dropbox.com/sh/382a8x5tsc6r2cz/AAAf_xMY0VPOob6KwGq2XUIna/old gpu.rom
Try these and see how you get on.
http://www.sendspace.com/file/cbcaw3
One of your cards had a very low TDP so that could explain the issues you were seeing.
I'm no expert in crossfire...but two crossfire bridges for two cards? Thought crossfiring two cards only need one crossfire bridge?
how do I use the files please? what card had the low TDP (also what does that mean please?)
thanks
ian
LtMatt said:HIS 7950 Ice-Q Bios Flashing Guide - Remove the Boost Voltage of 1.25v, Stop Usage Spiking/Throttling - Give your card a Permanent +50% Power Line -
Bios Flashing Instructions
You might want to write this down...
You need to create a bootable usb stick.
1. Download and install the USB disk format tool here.
2. Download the Windows98 system files here.
3. Create a folder called Win98boot on your desktop, extract the files from step 2 into the folder.
4. Plug in your usb stick. Launch the USB disk format tool. Copy these settings, then click format. You need to select quick format, tick dos startup and select the Win98 folder, like ive done below.
5. Click start, then ok and it should do it.
6. Download atiflash. Extract it onto the usb stick.
7. Download my bios. Extract it and cut and paste it into the usb stick.
8. If you've done everything correctly your usb stick folder contents should look like this. (except the bios should say Matt.rom instead of HIS7950.rom) Do not worry if you have more or less files than what appears in the screenshot. As long as you have the bios file and atiflash thats all that matters. Windows 8 users might have extra files like in my screenshot.
If you look to have a file or two missing it could be because you don't have show hidden files ticked in control panel, folders.
9. Make sure all gpu's in your pc are switched onto bios 1.
10. Uninstall gpu drivers and any overclocking apps. Do not keep settings delete everything.
11. Restart your pc. Before you hear the beep keep tapping F8. Boot from the usb stick.
12. You should be at dos prompt. Type atiflash -i to get the adapter number for both your gpu's. Typically it will be 0 and 1, unless you have a gpu in a third pci-e slot. You need the adapter number to tell it which gpu to flash.
13. To flash gpu 1 type atiflash -p -f 0 Matt.rom and hit enter.
Wait for it to finish. It will prompt you to restart but before we do that we need to flash the second gpu as well.
Now do the second gpu (if you have one)
Type atiflash -p -f 1 Matt.rom
Once that has completed and you get a notification saying you can restart press Ctrl+Alt+Delete to restart your pc.
All going well you should get a display and boot back into windows. Now you can reinstall fresh new drivers etc. Boost voltage and boost clock is disabled, your card thinks its a non boost card from now on in and you have the option to select 50% power setting as standard with every driver install.
If something goes wrong and you get no display from the cards after flashing the bios. Turn the pc off and flick both cards bios switch to position 2 to use the stock backup bios. Turn the pc back on and all will be ok.
Good luck.
The extra crossfire connector is just for connecting 3rd and 4th card I think?
woohar, im not sure if that is ott for me to try?? I have never changed a bios before
LtMatt
I have just looked at the gpu. My old card the bios switcg is on number 2 but the new card is on number 1.
Do you think that could be the problem?
Thanks
Ian
I was getting better fps with just one 7950, add another and things run slower
the card was second hand, this is the bios code from the new card, in switch 2
https://www.dropbox.com/s/ptlino6gx1d1v9f/gpu1 bios switch2.rom
thanks
ian
What resolution you playing at? 1080p and you'll notice a bottleneck. Using one 7950 instead of two will produce those exact results, adding the 2nd card increases use on the CPU which if it can't cope will lag behind.
That said you'd notice both GPUs with low usage, not just one I would have thought
Did the person mine with the GPU before hand? Could the bios have been tweaked for mining and the voltages/clocks hard changed that way.
they said that they did not mine with it, and it was only used for a very short time. but you never know for sure tbh
only used for a very short time = it's been used for mining
won't be an issue though although it's probably why the bios switch is in position 2.
try position 1 and see what the clocks are, they may of flashed the bios for you as I seem to recall boosting bios' were naff for mining.
When i got the card it was in switch 1, I have just changed it to switch 2 and posted the gpu-z results above.
I am trying to get the usb stick set up.
I have tried it twice so car and the only files on the stick are
atiflash
old rom
new rom
there is nothing about the BOOTLOG? I have it set to show hidden files.
where am i going wrong?
thanks
ian
