Most you get are useless, just gotta find the gems and keepers
Crafting Reapers Wraps is something you should do but not as highest priority imo, you have other stuff to work on.
I would run some rifts, highest torment where you can get to and kill the rift boss efficiently (sub 10 mins per run is ideal). Use Rift it Forward community to get people in at the Rift Boss to open your next one for free.
Gamble on Shoulders followed by Gloves in that order as those are your weakest slots, meanwhile you may find some upgrades.
Don't be tempted to spend all of your materials as soon as you get them, especially if you are getting upgrades frequently. Focusing on gem upgrades is a good idea as they will be useful from one item to the next.
Cheers, will start to spend shards on shoulders only at the moment then, hopefully get a good legendary. Will work on improving my gems as well, just so expensive!
So I should do the rifts runs solo? I'd probably get away with T1 in 10 minutes I think. Using the rift it forward community is a great idea, I'm thinking wouldn't it be better for me to just join a random T3 group though and do rifts that way? I'd get better gear in the long run I think?
Also any tips on the quickest way to get rift keystones? Just doing group bounty runs?
