Unfortunately we can’t test these theories since NVIDIA has strictly limited press coverage this time around, which is understandable considering the TITAN-Z isn't a predominantly gaming-focused card
HAHA!!
The digital storm review shows no compelling evidence to buy this card over the 295x2. Save £1.2k and go AMD!
What is the point of this card. Why not just buy 2x Titan Blacks, Wouldn't it be cheaper and faster?
Yes
You could near enough buy 3 Titan Blacks.
Review writers appear to be lost for words.
Yes! At the price compared to the competition!
I really don't like this card as it offers nothing that can not be done better by 2 Titan Blacks. There is not even a good argument for it to be used where space is tight as the cooler is a triple slot job and the heat getting dumped into a small case will cause problems compared to 2 reference Titan Blacks which eject the heat out the back.
That's no review...
http://www.geforce.co.uk/hardware/desktop-gpus/geforce-gtx-titan-zGeForce GTX TITAN Z
GeForce® GTX™ TITAN Z is a gaming monster, the fastest graphics card we’ve built to power the most extreme PC gaming rigs on the planet. Stacked with 5760 cores and 12 GB of memory, this dual GPU gives you the power to drive even the most insane multi-monitor displays and 4K hyper PC machines.
