**THE AMD DRIVERS THREAD**
Status
Not open for further replies.
Nope I'm just running everything stock :(
I've set my memory and CPU at stock too now and will give it a try.
Bit odd though as it's been stable for about 6 months...
Try my bios. :)
I only get it when i undervolt too much. The annoying thing is though i can't now undervolt as much as i did before. The black screen occurs when the memory switches from 150 to 1250. I saw a post on oc.net and someone there explained what happens when the black screen occurs and i think he nailed it with his theory. Obviously that doesn't apply to every scenario though.
http://www.overclock.net/t/1441349/290-290x-black-screen-poll/940#post_22350184
Does frame pacing not work for all games? I'm playing Saints Row IV and it's stuttering to hell.
On a 290 it should work in any title. Tried using vsync and or a fps cap? Could try disabling frame pacing as well, then try vsync and or a fps cap with frame pacing on or off.
My fps never hits 120 so vsync won't be useful. I guess the game is just badly optimised.
I'll try it with frame pacing off.
I'm not sure if this is a driver issue or an afterburner issue, but with my 2x 290X's, GPU usage in afterburner is the same for both GPU's. I'm sure it wasn't always like this but I don't know whether it happened when I updated to 14.4 or updated Afterburner. If I turn off unified GPU usage monitoring then both cards are separate but the usage is all over the place.
Any one else having the issue? Running 14.4 with v 3.0.0 of AB.
It's a driver issue according to Unwinder. Just use the alternative monitoring method if it's an issue.
I haven't had a single crash for a very long time but It was about 2am and I scrolled down in Chrome on a forum with a youtube video and this happened
No BSOD, no driver has responding just that ^ Never seen anything like it before
Something to do with the vram. Was it overclocked? Try disabling hardware acceleration in chrome and see if it happens again. The card is not necessarily faulty, so don't panic yet.
Nope no overclocking whatsoever, completely default in Windows!
Hardware Acceleration was disabled as well, computer was up for atleast 7hrs before that happened in chrome. It would suggest that Chrome caused it but I will keep an eye on it but it is the first time that this has ever happened, considering I completed wolfenstein the other day
Try enabling hardware acceleration then. :p
I'm not sure if it's drivers or what, but with my 7950s I'm now using 14.6 drivers and BF4 crashes within seconds of it loading when using Mantle. DirectX is fine.
Mantle was working fine when I was using the 14.3 betas, but as soon as I put the 14.4 WHQL drivers on I got this problem. I then rolled back/sideways to the 14.4 betas and still got the issue. I was hoping the 14.6s might fix it.
I've run a repair on the BF4 install multiple times now. And since DirectX works I'm not sure it's the game.
I use DDU to uninstall my drivers and for the 14.6s I uninstalled from control panel first and then ran DDU. 14.4s and 14.6s all installed without any obvious issues.
Well, last night I managed to play a whole round using Mantle.
Not going to claim to have fixed it just yet though, bit more testing needed.
Status
