Permabanned
- 1 Jun 2004
- London
ignore
Using the wire resistence program. (download it here, its good https://docs.google.com/file/d/0BxGcL1JOoEcyb2JRUGNKUFZpSDg/edit?pli=1 )
Random thought.
Is there an Android app that does the same thing? Would be kinda handy.![]()
Hi Gents,
Just about to get a nemesis clone from FT(http://www.fasttech.com/products/1645505). Can anyone recommend a good dripper to get with it (from FT)? I have a fogger V4 at the moment which I am loving so just want a dripper to test with and see how good they actually are.
Thanks all above. I might look into a Vamo V5, is that much bigger than a normal ego battery? Ideally I want to keep the size similar, and I take it I can just put my mini protank straight onto that?
Recommendations for 18350s? Looking at Torchy's on eBay currently.
EDIT: Just picked up 2 pairs of his branded ones. Better than the Efest's as far as I know.
I use them and AW IMR's both are good imo.
Got a KFL+ today, thats two now. both microcoiled at 1.4 and 1.6. No need for my KPT's ever again! Now I have two I might use one as a test bed for a low Ohm vape... Any tips gents?
E: Just got an email that the pre order for these is open. Do want!
http://www.ukecigstore.com/sir-lancelot-black-edition-pre-order.html
I've got the shinyitus thing starting again, I've been good for ages and not bought anything new, now all of a sudden I think i need everything....![]()
Well did my first micro with .28g wire, much easier to work with got a nice 1.9ohms for x6 wraps, with try it with x4 next time!
