***The Vapers Lounge***
Status
Not open for further replies.
Well did my first micro with .28g wire, much easier to work with got a nice 1.9ohms for x6 wraps, with try it with x4 next time!
Vaping on some 6mg juice is a very nice experience, didn't think I would like it. Just need my new drip tip to arrive as I will be a happy bunny.
So I bought my first kit, nothing special just the Kanger EVOD kit in black. Seems OK but getting a couple of dry hits and it's giving me a bit of dry mouth.
Is there anything special I should be doing? Is it just bad E-liquid? Or is it just a not-so-good E-cig?
Hi Gents,
Just about to get a nemesis clone from FT(http://www.fasttech.com/products/1645505). Can anyone recommend a good dripper to get with it (from FT)? I have a fogger V4 at the moment which I am loving so just want a dripper to test with and see how good they actually are.
Do not get that one! I gave one of the aluminium ones to my mrs and it nearly set her handbag on fire. Get the normal ones http://www.fasttech.com/products/0/10005773/1604509-nemesis-style-mechanical-mod
Thanks all above. I might look into a Vamo V5, is that much bigger than a normal ego battery? Ideally I want to keep the size similar, and I take it I can just put my mini protank straight onto that?
If you want something small that's better than a protank then have a look out for a microstick mod and a spheroid atomizer
Recommendations for 18350s? Looking at Torchy's on eBay currently.
EDIT: Just picked up 2 pairs of his branded ones. Better than the Efest's as far as I know.
I use them and AW IMR's both are good imo.
Got a KFL+ today, thats two now. both microcoiled at 1.4 and 1.6. No need for my KPT's ever again! Now I have two I might use one as a test bed for a low Ohm vape... Any tips gents? :)
E: Just got an email that the pre order for these is open. Do want!
http://www.ukecigstore.com/sir-lancelot-black-edition-pre-order.html
I'm sure we all have varied opinions, but I wouldn't personally go sub-ohm on a KFL. The air flow is just too tight on any I've used to get the airflow through the RBA that's required to effectively do it.
In my experience the KFL = extreme taste and a decent throat hit.
Do you have a half decent RDA?
Yeah since posting that, I've read much the same as you say. The general consensus seems that the KFL's sweet spot is around 1.3-1.8Ohms. I'll stick with my preferred 1.6 I think. :)
Nope not got an RDA, thought about it though. Just an Igo L or something. How often do you need to fill an RDA up? I think if i had to keep buggering about with it it would get on my **** after a while.... As in are RDA's more faffing than a RBA?
quite often tbh but it's not really a problem if you're at home or work or whatever. pull off cap, squirt juice - takes seconds. I wouldn't take one with me anywhere but it's a great way to test out new juices and gives great flavour and there's no worries about leaks or whatever.
Yeah and for that reason, I think a dripper wouldn't be for me.
Having a look around though and the Fogger V4 looks good though! :D
I've got the shinyitus thing starting again, I've been good for ages and not bought anything new, now all of a sudden I think i need everything.... :o
Looks like it's catching.
I just ordered a Vamo V5 after looking at this thread. A step up from Ego twist I suppose. :)
Hi Josh, something doesn't sound right mate. :confused:
Is that 28awg or 0.3mm Kanthal you are using?
10 wraps around a 1.5mm drill bit for me, gets me 1.3oHms
6 wraps would be 0.8oHms
Are you sure all the coils are touching?
Status
