- 17 Aug 2003
- Woburn Sand Dunes
what does it have to do to be viable? i use it every day without any issues?
Can I ask why people don't like Hangouts? Do you guys not message people over data, only sms? Even then, what do other SMS apps have that Hangouts doesn't?
If the other person is also using hangouts then yes they are free.
Remember to click the icon bottom left and select Hangouts instead of SMS because if it's SMS then it will always send as an MMS instead of via hangouts iirc.
I prefer Hangouts now as it merges chats and texts for the same person and I don't need to hop between apps to read up conversations.
Tried Disa and for someone reason it hasn't synced my texts and won't let me use WhatsApp through it or even acknowledge it.. Might stick to Hello sms for now.
You need the plug in for WhatsApp then you have to enable and verify your phone number in the settings
http://waplugin.github.io
Not sure about texts as it didn't sync mine either but I'm not too bothered
]Would someone be able to trust me the APK for Disa?
I got into the community & got "You are a tester, Download Disa from the Play Store" But when i click on the link it goes to We're sorry, the requested URL was not found on this server.
Many thanks in advance :x
[edit - ignore link works now]
panic over.
