Do any of you have the 8GB Vapor x 290x? does it make a big difference at 4k?
Dayum.. I can buy two of them max.
For 3 cards i'd probably need a 6 core CPU too right? My poor old 3770K will probably bottleneck.
So 2 x 290x 8GB in CF won't yield any good results ? How does it work Kaapstad. Do you need the extra horsepower for the VRAM to become useful?
So I have been playing with the 290X Tri X OC. Learned a couple of things..
Mantle seems to be the real deal. BF4 running under Mantle is really nice. Smooth fluid and no FPS drops.
Also learned that 290X's run hot as hell in Crossfire![]()
If only it was winter...
What temps you hitting?
In the 80c's. They generate a lot of heat in the case. My Antec 920 is struggling to throw it all out of the back of the PC
Might have to install some fans in top of the case.
Thanks for the explanation Kaapmuch appreciated.
Now to convince the missus I need tri-fire![]()
Crossfire IS toasty!! I had reference cards, imagine that
I think the Tri-X cooler will stave off throttling over the Summer, it was pretty warm today! Excellent cooler tbh, more than happy with mine. Would have cost me more to get after-market cooling than I paid to switch lol, it was a no-brainer![]()
No ****. My 290 crossfire Mantle performance annihilated my 290 crossfire DX performance.
My 290 DX performance was identical (in fps avg, frame time variance, stutter etc) with PG Tips 780 SLI DX performance.
Mantle is the real deal and its not even out of Beta.![]()
On a gaming site I visit semi-regularly a guy tried convincing me that Mantle gives no performance increase lol
