Nice. Like how you've mixed the green and blue led's in the res.
How does the top rad get any air in/out under the desk like that though?
Ah right. I thought you had a monsoon fitting with a green led in the g1/4 port and also a blue led in the central bit.Ironically, there is only a blue led. The coolant fluoresces green under blue light, which is just a spot of luck as it matches the colour scheme. (and when i originally found out, i hadn't planned the colour scheme)
TBH, i'm not sure how things will pan out regarding the lack of breathing room above. There is 2" above the case and 4" between the side and the wall behind. I can't actually use the top panel usb ports anymore as i can bearly fit a pen drive in the gap.![]()
Voltage for 4.5 is 1.275 in bios, 1.280 idle in windows and 1.296 running Asus real bench. Gaming temps on auto fan setting are into the high 70's, high 60's at full fan speed. Last time i ran p95 small fft it hit 94c in seconds. That was on a previous bios that required less vcore. Daren't run p95 etc at all now. Cooler is the k2 with x2 PWM 2350 rpm corsair sp fans.
