I just hope we start getting games that use all cores properly, but I think I will be waiting for another 4 years before I change the CPU, think I can get one more GPU upgrade out of this system first and overclock to 4.3GHZ with a 1.35v overvolt.
Thats jam packed with nice connections.
What MSI board is that ?
I am waiting to see what ASUS brings to the table for the x99 board.
I'll probably end up with a msi
A lovely Rampage Extreme V, cant wait!
Yeah between the good cheaper boards and the £50-£100 more expensive ones there isn't usually much in it and performance is practically identical.. saying that i'll wait and see what at least a few are like.
Only feature i can see missing that would be in future boards is PCIE4, probably only make a few % difference much like from 2 -> 3 i suppose.
Do you think new third party CPU Heatsink and Fans will have to come out for x99 boards?
I am not too sure of the CPU Heatsink and Fan compatibility with the x99 boards and the existing top CPU Heatsink and Fans on the market right now.
It looks like we might have issues trying to fit say a Noctua NH-D14 / D15 on those boards if the layout of the ram slots are similar to the EVGA teases X99 Motherboard.
Dear Mr. XXXXX,
thanks for contacting Noctua and for your interest in our products.
Since the basic socket design apart from the pins remain unchanged, there is no need for a new mounting kit. You will be able to use a NH-D14 or NH-D15 on LGA2011-3 as well.
Kind regards,
Andreas Karner
Noctua support team
