 - 10 Jun 2014
Hello,
This is my first computer i've built and after building it all i've powered it on and the computer turns on for about 2/3 secs then turns off again. It doesn't load long enough to get to a BIOS and i know its working and my 3 fans all start up. I have then taken each component out and ran it with just 1 stick of RAM, processor, motherboard and power supply. Even after doing this is still cuts out after 2secs, i also swapped the RAM stick around but still same problem.
I have included a list of what the spec incase there is a obvious hardware error...
I7 PROCESSOR - http://www.overclockers.co.uk/showproduct.php?prodid=CP-405-IN
GIGABYTE MOTHERBOARD - http://www.overclockers.co.uk/showproduct.php?prodid=MB-401-GI
1TB HARD DRIVE - http://www.overclockers.co.uk/showproduct.php?prodid=HD-257-SE
430W POWER SUPPLY - http://www.overclockers.co.uk/showproduct.php?prodid=CA-059-CS
OPTICAL DRIVE - http://www.overclockers.co.uk/showproduct.php?prodid=CD-136-SA
I only have connected 2 plugs into the motherboard, is that right? the large one and the smaller one. And thats all thats connected to the power supply and it still wont work.
Am i missing something here? I really hope its a simple mistake ive made, if you need anymore information please give me a shout as really want to get it working.
Thanks for reading and hopefully helping.
Jake
Jake
 uploading image of it now.
