- 28 Jun 2005
- Behind you
Can someone test FF in a high contrast mode (white text on black I'm using) on Windows 8 please. I cant seen to ve able to highlight text on web pages to copy ect.
"my browser has awesome addons but i don't want to use one to customise the layout." brilliant!
I like to keep my plugins to a minimum
The ad thing was a whole non issue blown out of proportion by forums. You can put the classic bookmark button back. Everything you need to know has been posted above by various good folks!
Finding FF29 not to be anywhere near as stable as the previous version.
FF29 will crash every 24-48hrs with a lot of windows and tabs open yet previous versions would keep running for a week and not crash. (it would get slower, but wouldn't crash)
Selekt0r Since the update I've got the very annoying problem that the firefox.exe process does not terminate correctly when you close the browser. Next time you try to open it you get a message about 'firefox is already running but is not responding...' and you have to kill the old process in Task Manager. It's happening around 30-50% of the time I close Firefox
May have to uninstall and reinstall to see if that will fix it...
You can launch Chrome with the command line argument "--disk-cache-size=N" (where N is the desired maximum cache size in bytes).Using Firefox for years.
I don't mind using Chrome but what puts me off is that there's no option to set the cache limit. Chrome would become sluggish once the cache goes above 100 MB.
One thing that annoys me is how to select text that is a hyperlink? Everytime I do it firefox thinks I want to drag the link. Holding Alt seems to allow me to select text in a link but it is not natural. Is there a way to be able to select hyperlink text normally?
