- 18 Dec 2008
I am trying to overclock my 295x2 but catalyst control centre only allows a maximum of 75C for my card. Is there any app or register key I can amend to let the cards max out at say 85C.
I have been getting crap scores with this today after a fresh windows install (16K) yesterday i hit 17.5K after running bench straight after installing the card
I think its hitting the 75 deg and throttling down![]()
Use on screen overlay of afterburner to tell you in you're hitting the temp limit. Disable ULPS via afterburner too for a small performance bump. Might want to enable Unified Gpu usage monitoring as well in afterburner. It's right next to Disable ULPS.
And disable frame pacing.
I never disable frame pacing, unless im benchmarking. For gaming it's always enabled.![]()
I think the OP is having problems with performance on the benches.
It may be an idea if he tries some of the game benches like Sleeping Dogs or Hitman.![]()
Seems to be throttling at stock settings too. 1018/1250
Tomb Raider using the settings in the benchmark thread.
Min 93.4
Max 153.7
Avg 120.3
left the benchmark running for a few min after the score updated and GPU2 was throttling.
Is the fan moving on the radiator and the gpu?
Fans are working fine. I even added a pull fan to improve the cooling when I installed it. I might replace the AMD fan with a better one and see if that can keep the temps south of 75C. Other than that I don't know what to do other than RMA the card as faulty.
