Seen the pre-order RRP for PC retail £44.84 its now on a popular website![]()
I will if I have to as a massive DR fan but hopefully somewhere else sells the retail version cheaper I think as its an XB1 port the RRP reflects that somehow as MS want to recoup their loses from PC gamerslike the look of the game but aint paying 44 sheets for it lol![]()
but sounds like its unfixable due to physics being linked to it & the code complexity.Seen the pre-order RRP for PC retail £44.84 its now on a popular website![]()
One of the devs talking off the record about optional 30FPS cap but sounds like its unfixable due to physics being linked to it & the code complexity.
Console trash is a little bit bit harsh its a complex open world zombie co-op + sp slaying experience with what are supposed to be next gen gfxconsole trash for £44? Whoever pays for this needs found and lynched.
Disagree with this, this is a new 2014 title. The 7970 / 670 are now midrange cards, can be picked up cheap second hand or bought brand new in re-brand form 280X etc.. Which are still cheap for the performance these cards give.
I would be more concerned if they said this game could run best setting on an HD 6970.. Do we not want to see any progress?
It could be way worse, people would lose their minds if they recommended a GTX 780Ti or R9 290X..
A current midrange card being recommend for the best gaming experience is a good thing.
This.
Bearing in mind the Xbox one is like a 7770!
And a 7970 isn't mid range. If we'd had a die shrink, then maybe, but we haven't, so performance hasn't moved on much more than what a 1150MHZ 7970 can achieve (In terms on stock performance of the current GPU's)
MO someone at Capcom messed up with the required specs unless we really are getting a very badly performing port.
This is basically the new king of Steam with regards to hardware requirements and it'll be just a basic port at best...until Witcher 3 arrives.
Games aren't ported.
There isn't reasoning against it in as much as it doesn't exist. As in it's not that I'm reasoning against them being "ported" it's that because porting isn't actually a "thing" in the way people state, then games aren't ported.
Games are compiled specifically for the platforms they are on. To bring them out on a new platform they need to then be specifically compiled for that new one from the source code.
Porting suggests that one version of the game is taken and then made to run on another platform, which isn't the case at all. You can't typically make a game run on another platform without the source code, and the source code isn't a "version" of the game. Ergo porting doesn't actually exist.
Some of the people would have you think the only things that you need to make a game work on certain hardware are the instruction sets (ie X86/64). This was one of the things people latched on to with regards to the PS4 and Xbox One. They believed "porting" would be "easier" because it shared the same instruction set as a regular PC.
Except that so do Linux and OSX and we know that games made for WIndows don't just natively run on either without having a build specifically made for each platform.
Very few developers even use the term "port" if you notice, it's nearly always games journos that make claims of things being ported (if you follow the sources) and talk about ports and porting.
