Were the boxes damaged in anyway?
Nope not a mark on either the card box or external packaging.
Its going back tomorrow I did not try and fit. I have ordered the Vapour X card so hopefully it will be OK and not rattle.
Another guy joining the fold with a vapor x 290![]()
It all began with a 670 side upgrade....
Ive got 14.6 betas installed at the minute. Are they the best ones to go for?
What have your temperatures been like? Surely if they was a fault then you and your mate would have over heating?
If not over heating then the contact must be good enough. I'll try take a image of my two but I won't be taking them out the case.
I decided to try one more MSI gaming card before giving up completely. Funnily enough this one also has the same issue that all 3 have had before in that the heatsink does not make proper contact with some of the components on the card.
The memory chip by the PCI-e port the heatpad is raised above the chip and also this part of the VRM circuitry there is very obvious daylight through rather than a nice contact.
I have had 3 like this now my friend has just checked his and it is the same. Could people who have the MSi 290 Gaming OC edition please check there cards as I think there is issues with the heat sink fit on these cards.
This is a pic of the VRM part which is just to the left of the 8 pin power connector. The memory chip is hard to photo as the gap is smaller although obvious if you compress the heat sink you can see the pad make contact.
Cheers
http://i734.photobucket.com/albums/ww350/F1REFOX2107/P1080559_zps7640f9b3.jpg[/IMG[/URL]
[URL=http://s734.photobucket.com/user/F1REFOX2107/media/P1080560_zpsa56fc4b8.jpg.html][IMG]http://i734.photobucket.com/albums/ww350/F1REFOX2107/P1080560_zpsa56fc4b8.jpg[/IMG[/URL]
Cheers[/QUOTE]
Wouldn't accept that at all, shows how much they test these things if something that obvious can slip through.
Cheers! Ill post some clocks up when i get it.
Shhhh, the waiting is killing meIt should be here tomorrow.
