^^^^worth mentioning the swift is 10bit![]()
This is massively true.
But is it all fur coat and no knickers? The underlying tech of TN is still largely the same is it not, so there are still advantages with IPS over TN, apart from just viewing angles.
Is making a TN panel 8bit colour like putting 2 coats of lipstick on a monkey? (phwooar)
No it's not
doubt this is going to have a smooth release
be fair to say this is one of the most anticipated monitors of all time
let's hope it's better than the opening of the world cup
There was much more buzz just recently around the Eizo FG2421 ... it just died once all the production and quality control issues came to light. After the first reviews, it seemed almost too good to be true ... and it was, sadly.
Really hope Sharp make an improved version of that panel, or do a second production run with some of the issues resolved (it appears it's not being continuously produced, but just had a limited run).
isn't that the monitor with the pseudo/false 240hz mode? I heard really bad things about it, it had a good chance being a VA panel, I just wish they didn't mess things up with useless gimmicky marketing features and made it true 144hz instead of useless 120/240.
afaik the only advantage of the 240hz was less motion blur, but with a Lightboost/GsyncULMB monitor it pretty much eliminates motion blur. So literally the only positive feature was that its a VA panel. sigh... why is the gaming market littered with gimmicks
