I tried mine and it hit 84.c in Watch dogs at stock clocks. The fan was fairly loud.
It's going back tomorrow.![]()
Ouch sorry moog
I hope your next gpu is better you seem to have terrible luck with cards
What is your case/cooling setup like moogleys? And room temp.?
Also fan speed of the gpu?
From what I have read, it just seems like these cards run hot and the twin frzr cooler isn't the best for cooling but very good for noise levels. overclock 3d.net were getting similar temps to me at both idle and load (although no mention on case or room temp)
Ouch sorry moog
@nexus you checked the heatsink/cooler is mounted correctly ?
Fractal Arc midi with 5 x 140mm Corsair fans. I can turn the case into a wind tunnel if needed....
I tried a custom profile but tbh it seemed to make little difference once the fan span up setting it higher did not drop the temp. 82.c is more than likely ok but I was only trying the card as it's going back anyway due to the heat sink issue.
I'd recommend the PCS+ as that cooler is a beast, but you mentioned crossfire so it probably wouldn't be ideal.
I too think its a great cooler but i can't really comment to much on it as i have not had the opportunity to test it against other 290 coolers.
Is it the part with a red circle around it that you are referring too?
So you advise me to get a RMA sorted as well then?
Since you have been through 3 of them and your friend has the same problem. I am not bothering with a replacement, will seek a refund and get something else
Problem is where do I stand since I have sold on the game codes for AMD golden reward and used the card since Friday? Think ocuk would consider this a "fault"?
Right, I will contact ocuk tomorrow and see where I stand for getting a refund.
No point trying another MSI card since moogley has gone through 3 and his friends plus mine has the same problem.
The tri-x would be too big for my case wazza![]()
Yes that is it. It might be worth taking the card out and checking the memory chip as well.
Me personally it annoys the hell out of me that it is not fitted or sitting correctly. I have no idea if it even affects the card at all but it's not right and the thermal pad being there says it should be touching. Also the ram chip is the same.
I would bet that they are all like this just nobody has noticed before.
I would contact OCUK in the support forum and see what they say. Mine did not come from here this time so dealing elsewhere for mine.
If mine don't reach passed 80c they both sit in 70s will give you guys a good idea.
Do your cards always hit into 80s no matter what?
But if it wasn't connected correctly wouldn't your card over heat?
ahh shame,maybe they have a bad batch? usually they are good cards,seems to me the whole cooling bracket is manufactured bent
