"AMD"Gaming evolved DVR beta
Does this alter the clockrates on the cards in CF if you have it enabled? The one flaw with shadowplay for me is that the cards won't underclock to 2D mode properly in SLI when its enabled, even if not recording.
Haha yes I was, haven't ran it in a while though as the pop ups were ******* me off :p
Glad amd are getting a shadowplay equivelant, hope the perf hit is as minimal as well :)
:p
You can disable everything that pop up in the notification part.
You can have it so the program will never bother you. It's highly customizable.
This.
It never disturbs me but i still get the benefits of using it.
Not been able to test, has AMD app added radeonpro OSD yet like fps counter?
Last time I tried the FPS counter on raptr is wasn't very good.
This the only reason I still have RP installed.
How do you get the in game overlay working for Raptr? Nothing happens when i press the shortcut. Do other overlays interfere with it?
What are points used for? Or are they just like XBOX gamerscore? (i.e. useless)
You gain points to be used for entering prizes. Or if you save enough you can get free gifts like a GPU or %off
Just for playing games and having it sit there in the background.
This basically.
It does use very little ram. That said i have 16gb so these days i find myself running as much stuff as i can just so the ram is actually being put to good use. :D
