- 5 Jun 2003
- sawley/ long eaton
looks good shaken,a wee screen maybe?![]()
funny enough I had thought about that, just not found one I like
ZX6R went today. I'm sure I can slum it on the Street Triple for a while![]()
ive also melted the rectifier wires from thumbing the starter too long trying to get it started (where it joins the loom under the tank)
are they good those nightbreakers?
I have some really good led sidelights from china I think,pure white light
@dreager I wonder how that water got in there in the firstplace? do you soak your air filter in oil?
SHE LIVES!!!!!
Drained the old fuel out. Refilled with fresh V-Power Nitro and added a squirt of Redex Injector cleaner. She started on the second thumb of the starter. After a few seconds she died. So I started her again and the same happened a few more times until she coughed and complained into life. Few pops bangs and wheezes and eventually settled down into a reasonable tickover, if a bit lumpy and rough sounding. Eventually coaxed her up to normal operating temp and let her tick over until the fans came on.
Bloody hell I'm so happy.
I'm going to do an oil and filter changed just now whilst I'm on a roll. Will check everything else like tyres, pressures, brakes, lights etc and take her out for a spin tomorrow as I'm going to let the oil drain overnight.
Is it any wonder she wouldn't fire though when you see the fuel that came out of the tank, arrowed is the water settled at the bottom. Disgusting!!!
I use wynn's dry fuel after the bikes been asleep over winter.
They look great. May well do that to my Gold Brembo's if they don't come up good enough when I give them a scrub. I take it you removed them to paint?
do em,just take your time,i only used regular matte black paint on my zx6 calipers,no high temp stuff,still looks good
