- 19 Dec 2010
- Berkshire
Where is the cheapest place to get Hubsan x4 spares and batteries in the UK?
Did you get a naze32? If so how did it fly?
Can anyone tell me what else I am missing for a 250 build please. Most of what I have ordered is copied from Rilot's build.
Anything else? No FPV stuff for now.
Is a 250 frame hard to fly if you are a beginner? Should I be looking at larger frames??
Have you got a lipo charger? How are you intending to wire it up? Banana plugs? Have you got the receiver to kk leads? Lots of spare props and a led strip might be really useful for orientation ( did some LOS night flying tonight).
Sorry forgot to mention, yes I have a lipo charger.
Now I just need to know what I will need for wiring it up and what power distribution board to get. What do you recommend? I am happy to solder if that's better then using plugs.
Also what do I need to wire up KK to receiver?
I went ahead with a FrSky DJT module with a FrSky V8FR-II 8
Around 8 minutes with a 1500 but they are heavy and I'm looking for an alternative![]()
I've just finished installing a 3g PDB which I'm happy with now. I had a 3.5mm banana PDB (too heavy). Tried a custom wiring loom (too heavy + looked a mess) but finished rebuilding with this and now happy. db_brennen is also using it:
http://makeitbuildit.co.uk/index.php?route=product/product&path=25_29&product_id=79
For wiring you could solder anything in which case just get the PDB above and thin shrink wrap tubes. I'm running 2mm banana connectors on the motors to ESC, and ESC soldered to the PDB. You will also need a XT60 or JST connector for the battery.
The leads you need are male to male servo leads. I used 15cm ones like this:
http://goo.gl/zlSc9L
Thanks for the help and links. I ordered the power board, leads and some 2mm connectors. I think I have everything ordered now. Just have to wait a while for the few things I had to order from the HK int warehouse as UK didn't have stock.
Excellent, they are great fun. Did you get the XT60 or JST lead to PDB to connect the battery to?
