R9 290X Owners Thread
did you experience any artifacts or crashes with the asus r9290x while gaming tommy???
Haven't really played on it yet, my lad abused it yesterday and the only problem he reported was Goat simulator caused a hard reset when he was spamming the **** of goat spawning.
Interesting airflow setup there, Tommy.
I was thinking that also.
Looks like all fans are exhaust? :confused:
The bottom two weren't meant to be exhausting...
Is it ready yet?
Is it ready yet?
Is it ready yet?
Is it ready yet?
Is it ready yet?
Is it ready yet?
Is it ready yet?
ready yet?
ready yet?
ready yet?
ready yet?
ready yet?
ready yet?
ready yet?
ready yet?
ready yet?
ready yet?
:oMaybe the DCUII OC can be quieter then.
Seems fine so far, it produces more heat inside my case though whereas the GTX 780 pushed it out the back of the cooler. Speedfan locked the fans to 20% though which I thought was weird and wondered why the pc was releasing epic heat when gaming! Turned off speed control for gpu off and now sorted.
It's a nice card.
Is it ready yet?
Is it ready yet?
Is it ready yet?
Is it ready yet?
Is it ready yet?
Is it ready yet?
Is it ready yet?
ready yet?
ready yet?
ready yet?
ready yet?
ready yet?
ready yet?
ready yet?
ready yet?
ready yet?
ready yet?
That explains it. :p
http://i.imgur.com/SFbgksR.gif[IMG][/QUOTE]
lol :D
Years ago I had a 7950, and used that to have 4 monitors for work on.....
2xdvi-d
1xDP
1xHDMI
then I got a nvidia 670gtx and that worked perfectly as well
Now I have a 290x and I cant seem to get it to display on 4 monitors, which is weird because before I installed the 14.7 driver it worked on windows default driver, i tried the non beta driver and same thing the missing monitor is the hdmi cable
Any idea?
I'm asking cause I have the same card and it showed artifacts on bf3,4 heaven valley etc.
the problem was overheating of the vrms and the core itself.
I thought that the card was faulty but then I replaced the vrm thermal pad and
lapped that awful surface of the heatsink and the result is better than expected:)
can I join the club?
On the Roll of Honour and welcome to the club.:)
has anyone got a Powercolor Radeon R9 290X PCS+ OC? if so, could you please run 2 benchmarks at stock 1050/1350. Heaven Benchmark 4.0 on Preset = Custom, Mode = 1920*1080 8*AA Fullscreen, Quality = Ultra, Tessellation = Extreme. and 3dmark Fire Strike benchmark.
thanks
Could do Heaven 4.0 on my Ref 290X at those clocks Gareth if it helps?
u could do mate
i just want to know/see if other Powercolor Radeon R9 290X PCS+ OC cards performance slower than other 290x's, because my Powercolor Radeon R9 290X PCS+ OC seems to performance slower than other 290x's.
I've tried everything to improve it.
what are the temps on the card while "heavening" gareth???
if it's too high maybe the card throttles.
btw my dcii 290x scores only 51 fps so you are fine i think.
are you sure that the other results you saw are heaven and not valley??
