Caporegime
- 18 Sep 2009
- Dormanstown.
Now get on the MM
The free gift? It is the LG Calibration unit:
Edit*
Oh yeah, for what it's worth, my original was of course an April manufactured one. This new one was made in July.
Yup just mask out the surrounding area so you don't scratch anything else and you'll be goodI used a black Tesco scouring pad though which takes longer but has more control over the final finish. I like a factory finish look!
I will do a little review of the LG calibrator later on and will post the video up. I'll calibrate the monitor as is right now which allows me to flick between before/after so the before part will be the calibration with the i1 Display Pro and after will be the one with the LG unit.
There is a visible difference between un-calibrated and merely OSD adjusted to calibrated, most especially in grey tones. Remember the probe is reading the shadow tones as well and putting the measurements into the LUT so darker shades are displayed correctly and with nice detail.
If anything it will help other LG owners decide on if they want to plump for the i1 or buy the cheaper LG one. One being only usable on LG monitors of course![]()
New free monitor:
^Both photos taken using the same camera settings.
I think I will keep the new one and sell the old one. While the bleed is acceptable to most people by the looks of it I'm just deciding on if I should send it back for re-repair now or just sell it and bundle the calibrator along with it. I'm happy with the new one. Minimal bleed, minimal IPS glow.
Edit*
