This is nvidia, they did after all replace the gtx 670 with the worse performing 760.
The 670's replacement was the 770..
Wasn't the 770 mearly a GTX 680 with some sort of core boost thing?
The 760 was the replacement for the 660?
760 was the 670 replacement iirc according to Nvidia, 680 was replaced with 770 not 780, titans and the 780 series were a new higher tier
No chance. (except for the 28nm bit)
You really think that nearly a year and a half after the 780's release they are going to release a card that costs more but performs worse? That would be business suicide.
My Guess
28nm
Performance slightly less than a GTX 780
Price slightly more than a GTX 780
This is a midrange card hence my prediction for the performance.
The top of the range 20nm card that turns up next year will be a lot faster.
Erm Kaap you realise this is the Nvidia GTX Titan II Flagship with GM200 Core Is Launching Sooner Than Expected_ thread not ethe 880 one, methinks you are getting confused.![]()
If it is marketed as a mid range card it wont be more expensive than a 780. Even Nvidia know they wouldn't get away with releasing something 1 and a half years later that doesn't perform as well, but costs more money.
This time around, I reckon if it is around 780 performance it will be released at about £250 ( perhaps an 870?). Then £350 for the 880 which will be more like the performance of a 780Ti. That leaves them the £450 and £550 price brackets for the GM200's.
It did but not a great deal, in nvidias eyes it took amd over 6months to even match the original titan, even then a 780ti and titan black later and they nudged back ahead...If amd want to give them something to think about they need to be the ones setting the bar![]()
You mean the "Some Fanboy over @WCCFTECH is putting 2 and 2 together and getting 57" thread.![]()
