R9 290X Owners Thread
Hi Humbug, it is not overclocked. I think when gpu tweak is set to powersave it does underclock the card. Max temp is 82.
If you are having problems keep well away from GPU Tweak as it can be quite buggy.
Once you know what's what then go back to GPU Tweak.
I recently bought a Asus Matrix R9290x-p-4cd5. Having lots of problems, when playing Crysis 3 after about 5 mins start to get white flashing artifacts, slowly get worse then blackscreens. Have to alt tab to task manager to close Crysis, gpu tweak shows the mem stuck at 5400. Tried fresh install of win 7 on new disk, still the same. Left sides off case and set fans to max still black screens. If I set gpu tweak to power save it does not blackscreen. If I put 7970 matrix back in all runs ok, no blackscreens. What do you think the problem is? Running win7 x64 and catalyst 14.4.
most likely it's faulty..
i'm had 2 asus 290x which both was faulty.
Been doing some testing, in Gpu Tweak profiles if I set it to power save which just seems to drop the gpu clock from 1050 to 1000 I get no blackscreens.
If you are wondering why that EKWB water block for your AMD Radeon R9 290X or R9 290 didn't fit
Yes?
it's because there are multiple board designs being manufactured. This new board, the R29FA, is a reference board that is slightly different from the original design. The new board design can be found on Power Color, Club3D and VTX3D cards.
ah ok.
