It's not just cloning - I used robocopy to copy my game files back to my freshly formatted drive and it had the same impact. It gets about half speed and spiky on any area that has data on it.
Some of it may be down to the flash memory used. I've been testing my MX100 256GB which is approx half full.
Test in HD Tach :-
Interestingly in HD Tune I get a far better result...
.........but that was on 4MB block size. Setting it to 64KB gives similar results to HD Tach.
Speeds are generally down a bit overall since I'm using the Marvell Sata 3 port as the two intel ones are in use with the Samsungs. Speed of first half only really starts dropping if I set block size to levels below 512KB.
On the samsungs I don't think it's the initial drop that's the main issue when fresh though, it's the spiking. Performance seems to drop drastically after a bit of use going by some of the earlier graphs.
Two differerent issues possibly on the evos - a caching issue for low block sizes and trim not working or going odd long term?
Test in HD Tach :-
