I agree. I simply cannot go back to anything <144hz and/or G-sync. Would kill for a 32" 144hz/Gsync.
I've been torn between the Q2770PQU and BL3200PT for a few days now and didn't get the super LG widescreen (can't be bothered looking for product code) whilst it was on offer for £719.99
However, these Samsung models look aesthetically pleasing as only a Samsung could so now I'm torn between the 27" and 32" models
Will almost certainly order one of these and maybe an additional 290x to go CF. Let the countdown to the 19th Sept begin
Edit: Can anyone confirm for definite that the 32" model has the same screen as the BL3200PT? I have just noticed the BL3200PT is due in stock on a rival retailers website on 09/09/14 and is slightly cheaper than its 32" Samsung counterpart. Hopefully Overclockers will place it on offer in the future, would much prefer to buy from here than 'the others' where possible if I chose the BL3200PT over the Samsung.
I pre-ordered from that site when they were supposed to get a delivery on the 15/08/2014. Never happened and now they are quoting 09/09/2014 that pretty much a month of waiting. If OcUk get them in I'm just buying it from here as I can't be bothered waiting anymore!
delayed again too apparently.
ok getting a bit lost here just want to know what the differents is from a D to a T?
The 'D' is just an error. The model has a 'T' suffix. It's a bit strange as Samsung usually uses a 'D' suffix on such models - hence the confusion here.
Ar nice one thanks for that. was getting a bit confused as ****** have ones with the T at the end just didn't know if they are two different screens or not. wish there was a review on the screens. Just want to know if they will be any good for gaming on(r9-290 GPU). got an old HP 2309m at the min lol and have been saving up most of the year to get a new one. didn't want to get a TN as the color don't look as good but on a plus there fast. anyone know if you can overclock the Samsung ones past 60hz?
The Benq is a lot more expensive on here than it is from another popular retailer.
PCM2 -when you saw the 27" version do you know if the casing was plastic or another material? The last Samsung I had was a 22"lw or lbw and that just felt really plastic, I'm a little apprehensive in buying a new monitor as right now I have a really good NEC 24" screen and although it's a TN panel it's very good and has an excellent contrast and I'm just worried in getting an inferior panel.
Hopefully these are an improvement.
