- 26 Dec 2003
- Cambs UK
me too, if they don't patch it before about 8pm :/
Why would they patch it? It's just the game, there are plenty of areas that have respawning enemies.
This is a mission related setup, as when you die, you get to do the area again with drops on ground, so they may patch it as opposed to a loop farming method on patrol.
But who knows!
Just got a blue engram heavy weapon which says could be uncommon,rare,legendary.
I'm level 19, should I wait till I'm higher level before decoding or does it make no difference and just luck?
Some people on here say they always get the lower rubbish and not any rare stuff.
I need the materials tbhtbh, farming random mobs isn't really the most reliable way of gearing up, and it's boring as ****.
if your time is limited in any way, you are probably far better off grinding vanguard / crucible marks and faction reputation, then you can buy legendary items tailored specifically to your playstyle, instead of praying to RNG-sus for a random drop.
you could wait til lvl 20.
engrams will decode at the level of your character, not the level you were when they drop (as far as I am aware).
i.e. if you decode at lvl 19, highest lvl item you will get will be 19, so better to wait til lvl 20 for a chance at a lvl 20 item.
I saved almost all of mine until level 20. Then when I used them all at lvl20, I ended up with 2 things that I actually wanted. was pretty gutted tbh. Seeing as you are so close you could wait, unless you need something now.
Hi all just wondered something, I am seeing some Xbox one Destiny bundles, It has written next to it a value of £35 of Destiny credit .....my question is, can the £35 credit be used on ANY item in the Xbox Store, or just the Destiny expansion pack?
Played the earth strike last night, me level 13, my two friends 5 and 6 - was pretty hilarious but we managed to get through it!
