TBH, I'm more interested in OCUK's testing process. As they've sent me a replacement, I took the view that implied there was a fault with the original. Do they automatically send replacement stock before they testing returns?
No, what I mean is surely they would test the returned item before deciding whether to send out a replacement or original? If they send out a replacement it implies that they have also seen a fault with the original. Given that the fault is exactly the same on this replacement then the issue is more than likely with my psu, in which case the original that was returned to OCUK must have passed testing.
i can say with 100% confidence that MY HX1000 could not power the 295x2.
shame because I love that power supply.![]()
If you RMA'ed it, it will say on the invoice if replaced or no fault found.
Hope my evga supernova 1k can handle it.
Aha! You had a similar problem? Can I just double confirm that you have tried a Radeon R9 295x2 with the Corsair HX1000 and found that it doesn't power the card? What symptoms did you see?
it must be the internal power config of the card because the HX1000 powered my 2x290X's without issue. But the 295x2 wouldnt even post. Fan would spin etc but thats about it.
popped it on the superflower and it worked without issue.
Panos, thanks for your reply. I'm happy to concede it is time to replace my ageing and dearly beloved PSU. I'm contemplating a 'Be Quiet! 1000W Powerzone 80 Plus Bronze' as a replacement. That should be ok, right?
