I have been using
for a few days
The Specs
So far I've been quite impressed it's easily as good as a GTX 680 only without the heat soak and noise.
On league of legends it holds a nice and stable 220 fps temps ramp up to 72 degrees, fans crank up to 50% and the temperature doesn't move just stays at 72 which is fine.
Same on CS:GO no drops holds a decent and stable fps at 1080p with most things on high Again temps ramped up fans matched and just held the temp at a point. Fan noise isn't that high either.
will install battlefield and have a play this week.
Might even do some benchmarks.
But I can assure you if anyone wants a cheap card the 285 is a fair shout from where I'm sitting and I'm a team green fan.
Any news on the 285X yet? My feeling is AMD might launch it quite soon
I picked up a Sapphire R9 285 OC and it works fine graphically, runs cool etc. However, in anything with DirectX acceleration I'm getting audio glitches. I've verified it's related to DirectX specifically - if I use OpenGL renderers it's fine. If I uninstall the graphics card drivers it's fine. Run something as simple as a video in VLC with the Direct3D renderer and I get clicks/pops every few seconds but switch to the OpenGL renderer or any of the others and it goes away.
The rest of the machine is no slouch - it's brand new 5820k build with 16GB RAM, SSD, Gigabyte GA-X99-UD4 and 750 watt corsair PSU. I'm not doing any overclocking.
Anyone else experienced anything like this with one of these cards?
Can't say that I have, which drivers are you using ?
It appears Tonga does have 2048 shaders and a 384 bit memory controller:
http://videocardz.com/52834/full-amd-tonga-gpu-might-feature-384-bit-memory-interface
And yet according to folk at AMD there will be no 285X![]()
They are probably going to call it the 370X or the HD8970 just to confuse people further![]()
