- 10 Nov 2006
- Lincolnshire
Yup
I'm literally in the middle of putting together a 5820k + Asus X-99A. Was forced to upgrade due to a leaky radiator which killed my old mobo.
Only problem was while racing to meet the 4pm same day dispatch deadline I bought the OEM CPU so I'm having to wait till Monday for a cooler now![]()
FYI Intel do not include fan etc in retail chips either anymore ( which I only found out recently)
Hope your new setup works 1st time
What do you guys think would be a realistic overclock for 24/7 use on air with the 5820k ?
. Only crank it further for benching, up to 4.5Ghz
Although mine is not a very high OC, it is stable, I left it running prime95 most of the day...perhaps I should consider a water cooling solution. Just disappointed from my own efforts when you guys are not using much volts at all...
Cheers FrankJH, X99 is def having it's share of teething problems. Was your board working to start with or DOA spot35?
How are y'all choosing motherboards for your Hawell-E's? I've read CustomPC (only reviewed a couple of mobos), and had a flick through customer reviews, but still really struggling to choose.
Are the cheapy ones really much worse than the premium ones?
I've noticed quite a large variety of times with different motherboards over the years.
