Anyone online needing to do the weekly or fancy helping with it? Pretty please![]()
Sent you a message mate
When capping in control you know when an enemy is approaching from your radar so you should be ready to take them out way before they get close enough to take you out with a super. You can't always do it solo but if there's a few of you capping it should be easier to take them out.
Everyone has access to a super and knowing that I have one and use it from time to time I don't mind too much when I'm killed by one.
Also everyone has access to heavy ammo, you just need to listen out for the announcements (incoming and arrived) and get to one of the many spawn points first, which are always the same. Again, I don't mind if I'm killed by a HW as I know I could have had it first if I'd got my arse in gear.
If you got something that wasn't for your class would it make you consider making a character for that class? How I justified the engram - makes an excuse to try the other classes if you don't get the short-term luck you are after...hi
Im looking to buy an exotic from Xur but I'm not sure if I should chance the exotic helmet engram or use coins to buy the Achlyophage Symbiote helmet for my hunter of which I'm a hunter gunslinger class.
Obviously the engram is a bit more risky being random class and I have 20 strange coins so it shouldn't take to long to get enough for another exotic later on.
what do you think is the Achlyophage Symbiote anygood?
thanks
Honestly kissenger you are coming over as someone that just isn't good at Crucible (specifically object based modes) rather than pointing out some valid issue with how Supers work in the game.
Perhaps you just aren't as effective at using your super rather than the mechanics of PvP being the issue...
EDIT: and your reasoning regards not jumping out of a control point is flawed why would you allow yourself to get supered rather than jump back surviving and then clearing the enemy who hasn't realised he missed you with his super and then go back to capping?!?
ps3ud0![]()
What else are you gonna use motes of light for anyway
ps3ud0![]()
You need to give examples of control points on maps you can't escape from as I can't think of one where you either don't have multiple exits, a long enough line of sight to see the enemy or can't use the radar to get a bead on the direction/entrance they are coming from...I don't get what you're saying on the second point. Of course you try and get out of the way when someone supers, but that's nearly impossible to do on certain cap points because you're dead before you can react, or there's simply nowhere to jump.
I was thinking that but I dont think I can be bothered doing another class.
I could keep the motes of light for next week to see what Xur has to offer, I just wondered if the Achlyophage Symbiote helmet is good while its on offer?
Don't make the same mistake I did this morning dude! - Save your motes of light for something guaranteed - I ended up with a flippin titans helmet (when I'm a Hunter).
I did use the strange coins to buy a Helmet for my hunter though as it was my first exotic item and was only 13 strange coins (I still got 13 left hopefully for a decent exotic weapon next week).
is there some other way to get them that im missing?
If you have a kill streak going and they get their super before you then they have a better kill streak going than you, or they have configured all of their perks and intellect to boost their super energy.I don't like getting a kill streak going and then having it ended by a worse player than me just because they have super charged and I don't.
Army of dancers, I like that![]()
