And what if the leader hit the slow zone has to go 50mph or something, then the incident is cleared and the guy behind has no slow zone warning? Hardly going to be fair.
Tough luck. It's already the case with the safety car + pit stop rushing.
They need to add areas before all the major corners where they can temporarly close of the corner and let the drivers take a different route while the car is removed.
All it would take is a straight bit of track/road before the corner linking with the track after the corner.
This way the race goes on and everyone is safe to remove the car then they can reopen.
I think its a bit of an overreaction to this freak event that I cant recall happening before.
Much more danger in the pits with the speed limiters in place.
You can't recall 2 cars going off at the same point before? Or a car going off under yellow flags?
Have you never watched any motor racing at all before Sunday? Actually no, even that doesn't work, as one of the Caterham spun under yellow flags while following the Safety Car!
Err Wut?
Going off and hitting a 5+ ton JCB that's already attending another off![]()
You've clearly not grasped the context of what we are discussing here.
unsafe releases into other cars, wheels coming lose from not doing the nuts up, mechanics being hit when the car doesn't hit its marks.
Keep trying![]()
Which would all be a hell of a lot worse with much higher speeds in the pit lane
Yes, but my point is more risk happens in the pits with limiters than out on the track.
Its not like that JCB is always where it is out on the side of the track which makes this crash a "freak one off"
The outcome of the event is rare, but the event itself happens all the time.
Bianchi could have hit nothing, or he could have hit a marshal, or he could have hit a marshal and the truck and Sutil and parts of his car could have hit spectators. Should we only look at solving this one specific outcome (or as you suggest, not bother), or should we look at solving the root cause of why/how a car left the circuit under yellow flags and was placed into a position where he could hit a recovery truck?
If you step on a drawing pin, do you just put a plaster on the wound, or do you pick up the pin?
Where did I say "not bother" please show me.
Instead of people saying "dry races" only "slow down using limiters etc" they should perhaps not have a 5+ton JCB out on track but rather some long reach arm/crane.
Also yellow flags you say? well this video shows green being waved directly at the scene - https://www.youtube.com/watch?v=_uYpbi66ppg
After? looks directly on top of it.
What are you getting at...?
Nothing.
You are the one who said waved yellow flags when its clear that green is being shown.
I never mentioned or brought up anything about the flags until you did.
(but lets assume Bianchi saw this green flag and speed up causing his crash to be more severe so maybe the marshal is at fault?)
