Bog standard lock nut works for me
Yeah, me too. It's the actual adapter that screws onto the top of the bell that is out. You can see when it's screwed on as the screw drops way down into the the countersunk hole, almost passing right through. Casting issue I guess.
Anyway, it flies now
So that's a success. Didn't manage to get out today due to massive hangover so Project Hex has started now.....
Frame quality is ok, haven't weighed it yet, but will do when I can. I won't be using the lower "dirty" part of the frame as it serves absolutely zero purpose. You can't mount a gopro to it and my battery isn't exactly sensitive to vibrations. So this will end up being built like a classic 250, with the battery on top with the mobius.
The FPV Cam bracket is exactly the same as the one from my ZMR 250.
Motor mounts are really designed for 1806 motors I think. The screw slots are tight for the 2204's as is the center hole. Both will need embiggening before I mount the motors properly. The little dip at the end of the arm also leave the motor a little exposed in the event of an "event" but I'm really going to try not to play lawn darts with this one as the arms aren't really replaceable without buying another frame at the moment.
FC mounting holes are rubbish for the naze, so it's either an adapter plate, or sticky back plastic. makeitbuildit have an adapter plate for £3 ish, so will order that and see. I'm too lazy to make one and rubbish with precision drilling so don't want to start modifying the frame plate.
The CF looks real, roughly the same dimensions as the 250 frame thickness wise.
Just need to start soldering now
Oh, and decide whether to go SuperX or Naze for the build. The SuperX with GPS, IMU, IO Unit and OSD weighs in at around 200g vs about 10g for the Naze32. Might give it a go and see if I can shoehorn it all in just for the added confidence of flipping on the GPS if things go wrong.
Weight shouldn't be a problem with around 2.4Kg of thrust with 5030 props and around 1kg at 50%
5040 props will give me 3kg of thrust with around 1.3Kg available at 50% throttle.
AUW with superX will be around 950g, with the naze; 750g
Gonna use my X8R rx regardless as cleanflight works with SBUS and I mullered my other D4RII, one of the antenna is loose and the other one has detached completely, taking most of the track where it was soldered on with it.
I must stop breaking things really.
