Corsair Gaming CGK65 RGB Cherry MX Red 10 Keyless Mechanical Gaming Keyboard (CH-9000072-UK) @ £109.99 inc VAT
The Corsair Gaming K65 RGB mechanical gaming keyboard begins with the durability, styling and responsiveness of the original K65, and adds multicolor per-key backlighting for virtually endless lighting combinations. It’s built with 100% Cherry MX RGB key switches for fast, precise actuation and superior feel. Each key can be individually programmed to display any of 16.8M colors and multiple brightness levels for a level of customization never before seen in a mechanical keyboard. Full key rollover and anti-ghosting ensure accurate gameplay. And, the K65 RGB is built to last, with a black anodized brushed aluminum finish that’s sturdy and lightweight.
Product Features:
- 100% Cherry MX RGB mechanical key switches for ultimate performance
- Stylish and likeable 'Corsair Gaming' Logo
- Multicolor per-key backlighting for virtually unlimited game customization
- Aircraft-grade anodized brushed aluminum for superior rigidity
- Entire keyboard is programmable to assign a macro to any key
- 100% anti-ghosting with full key rollover on USB
- Display controller driven fast and fluid 16.8M multicolor animation
- Onboard memory to performance and lighting settings with you
- Ultra-Portable 10 keyless Design
Specifications:
- Cherry MX Red mechanical switches
- 45g Actuation Force
- 2mm to actuation and 4mm to bottom
- Rated to 50 million operations
- Gold contacts
- Up to 1000 Hz USB report rate
- Selectable 8ms, 4ms, 2ms, 1ms and BIOS mode
- On-board memory to store performance and lighting settings use on other PCs
- RGB LED backlighting with key-by-key programmability to light up individual keys
- Aluminum unibody construction for increased strength, durability and rigidity
- Easy access multimedia keys
- STOP, PREVIOUS, PLAY/PAUSE, NEXT, MUTE, VOLUME UP/DOWN
- Windows Lock key for uninterrupted game play
- Product Dimensions: 356 mm x 166 mm x 37mm
- Product Weight: 863g
Only £109.99 inc VAT.
ORDER NOW
