?What are the temperatures like on those?
Trying to use DSR on Shadow of Mordor.
So I go into "Geforce Experience", then "Shadow of Mordor" and it will not let me select a resolution. So I just clicked "optimise". Is this normal?
I seem to be able to change "DSR" settings in "Global Settings" in "Nvidia Control Panel" but it just says 1.2x 4.0x etc.
you need to set which ones you want available in the control panel... don't worry to much about Gefore Experience...
So go into control panel and choose which ratios you want to use.. i have 2x and 4x ticked and then i put smoothness at 50%
No when i go into games I have extra resolutions i can choose... 3620x1527 (2x) and 5120x2160 (4x)
Just make sure you turn of Anti Aliasing as you wont need it...
You will find text smaller and maybe hard to read but so far all the games I have tried it looks really good... there is a small amount of aliasing but only noticeable really close up.
That looks class AdzI wanna go SLI but my CPU is too old/slow. What motherboard have you got, are both cards running at 16X speed on the PCI-E slot? Can you run Heaven for us too?
I think you could be right about dsr not liking sli, when I use it my first card gets really hot (over 90c) so I stopped using it
4k DSR really does put a strain on the GPU, more than any kind of supersampling AA would at 1080p. Remember to turn AA off in games if you're using 4k DSR.
