- 25 Nov 2011
- The KOP
PMSL![]()
Tie that in with locking down Ubi as the major TWIMTBP partner and you are onto a winner with ear bursting **** gaming.![]()
You're trying to compare apples to oranges, the 780's were roided up supercards that appeared between the 600 and 900 series, the was no equivalent between the 7000 and 8000 series, this is an easy mistake to make as the Titan/700/290 escalation scenario is a unique phenomenon in GPU history.
Compared to the 8800GTX the perfect comparison is the GTX980/GTX690 & 8800GTX/7950GX2, and in that comparison the GTX980 wins, it is cheaper than the 8800GTX and performs just as well against it's predecessors.
Another card that gets remembered fondly for it's impact is the 9700PRO, in this case it's even more blatant as the performance difference between the 980 and a 780ti or 290X is significantly bigger than the advantage the 9700PRO had over the 4600ti (granted it is slightly more expensive but it evens out).
"The Way It's Meant To Be Squealed"
The 9700pro rick rolled the 4600ti. I am not sure where you get it was close. Sure when the resolution was low and no aa/af was applied the 4600ti could keep up but when it was applied the 9700 pro was up to 4 x faster. The gtx980 is no where near in the same league.
http://www.anandtech.com/show/970/20
http://www.anandtech.com/show/970/18
http://www.anandtech.com/show/970/21
http://www.anandtech.com/show/970/19
i wouldn't know.
To be fair my 290xs squealed also
That said, Powercolor are leading the way by adding glue to their 290 coils. If only other manufacturers would follow suit, it'd solve the massive headache of coil whine.
It did make me wonder why you know so much about it
https://www.youtube.com/watch?v=Zmk778tAC40#t=52
Read my post.
Maybe be best to read his update?
UPDATE: Even with asus 780 i have heard coil whine just less noisy. I have seen lots of videos and read a lots of articles. The conclusion was that it could be PSU. So I decided to investigate the source and took PSU (CM m700) from case and found out that coil whine was coming from PSU. Maybe I was wrong and R9 290x was completly ok but I will never know for sure because I returned it.
The problem with looking at paper benchmarks from 12 years ago is they don't tell the full story, I owned a 9700PRO and a 4800ti (4600 with 8x AGP, didn't affect performance) and yes the 9700 was better with AA on, but it still wasn't good enough to want to play with AA on, simply put higher res w/o AA looked better than low res with AA (this was true on both cards), so while the 9700 had an AA advantage it wasn't much of a real world advantage.
I'm not saying the 9700PRO wasn't more powerful than the 4600ti, it most certainly was, but the gap is nowhere near as big as revisionist history likes to believe.
