Would work until you have to cleanse. Would have to get the relic holder up there as well!
warlock will be ok ... just needs the right timing i think
EDIT: Hunters not sure about?
Don't think you can revive yourself when you die from being marked - still trying to find a way to get the relic holder back up there but it seems unlikely once you figure the Templar is also shooting at him too ans the floating platforms strip you of the shield.
ps3ud0![]()
Good they are fixing it, not interested in completing hard doing the above anyway.
They should open the new path way to templar on hard mode only.
Hard mode, you require 3 defender Titans and 3 warlocks i think, with raid weapons at 300.
Thinking about it could just stay at the top and don't jump down? Or maybe keep two players up top with a sniper. One titan on each side and in the middle at far back with the last warlock.
That does work, that is how 4 man teams have done it but you need to kill the oracles and hope no one dies. I think that just makes it more risky as the people up top can become lazy due to the lack of threat from attacks meaning the guys down below have to deal with double the agro and maybe lack of above ground support.
I would guess it would work fine for 60-70 of the boss fight but like most of these plans they usually fall apart on the last 30% or so when there is twice the amount of mobs etc.
Annd due to popular demand, it's going to be a Normal run instead!
PS4 Raid Normal Friday 8:30 PM
1) UberGinge (29 Warlock)
2) srg_johnson32 (28 Hunter [29 depending on shards])
3) MaxiLive (30 Hunter)
4)
5)
6)
i have a save for hard, you guys could try tonight before its removed?
Is that at Atheon?
nah, first boss i'm not that good yet
When did maxi hit level 30?
I'm sure he joined someone on Raid Hard via DLFG and lucked out super hard with the raid helmet at some point last week.
I'm up for giving it a go either way tonight if we have some people about![]()
4)
5)
6)
What part of the first boss, because if its just the conduits/oracles we could just run it from the start tbh - take 15mins...nah, first boss i'm not that good yet
356 strength, i hope he likes to melee everythingmaybe not so lucky ...
Let me know what time.
4)
5)
6)
Is this the normal Friday one we do? Ill be around as always with a 29 Titan or 28 HunterAnnd due to popular demand, it's going to be a Normal run instead!
4)
5)
6)
