Oh wow, tried a few of the digby juices now and this Hooligan was is very nice! My favourite so far. "Cherry, lemon, Oranges and Limes combined with a bit of fizz."
Do recommend!
It does show that taste is subjective. Once you smell that Germolene it never leaves you.
I really struggled to finish a 10ml bottle of it and that was only because Digby's 'The King' was even worse!.
Just ordered a gold package from zamplebox as well. £40 shipped to the Uk for between 120-180ml of top quality juices. Not to bad at all but I hope it gets through customs alright
Have you received this yet?
Wondering how long it takes.
.What is everyone using on the istick? All the atties I have would overhang and look pretty daft. Maybe people don't care since it would be a good vape anyway? I do like the look of it but wonder what it would look like.
Scopes site has been down all morning and all afternoon so far
Wanted to get me some tart so I could give her some of my secret sauce.
My bet would be on the screw not being well insulated on the Kayfun clone. It could cause a short if that is the case but the MVP should protect from that. I'm not really that much of an expert but that is my thoughts on it. I'm fairly sure a lot of people put new orings on their kayfun clones to stop this issue. I think it was kayfuns but I'm a bit fuzzy if it was or not.
Nautilus coils have a screw-thread on the top of the head that screws into the chimney which holds the tank together, where as the other does not because the upper section of the tank screws to the base that the coil's sat in.Just replaced the coil in my aspire et-s tank with the newer bvc type.
Nice improvement, better taste and less dry.
Just wondering does anyone know the difference between the smaller bvc coils and the ones in the nautilus mini. Would a nautilus mini be a step up again or will it be just the same as my et-s with bvc.
I use it with a itaste mvp 2 mainly if it makes any difference.
