Think out of the box. That slot there doesn't have to push hot air out but can pull cold air IN. And use the front as exhaust. I have it like that on my new case. The fan is pushing cold air into the case, on that slot above the card. I have to heavily overclock it to 1190 to get to 70C while benching.
Also your case is watercooled. There is no reason to have much negative airflow (going out), because nothing generates heat, while the PCB fan is blower type and gets heat out of the case, and not in.
I have 2 case fans (front) blowing cold air IN. Also 2 Apache on the H100i are vertical set blowing cold air in (on the drive bay). The 295X2 rad fan is blowing cold air from the back, and there are 2 140mm fan on top of the case blowing cold air out. Ambient temp in case 17C, after 3 hours playing Alien Isolation just right now.
Might give it a try tomorrow but going by reviews I doubt it will make much difference, the 295x2 is billed as a 4k card yet even in eyefinity some games are pushing it to the 70c mark. If you factor in another 1080p display on top of the 3 for eyefinity id imagine that it will throttle regardless. Also the pcb blower is a centre based one so a lot of the heat is actually being dumped into the case, only some is going out the back and if you take into consideration the card has a lot of vents on it id wager more is going back into the case than exhausting, in terms of vrm temps at least.
I was intending to make the switch to 4k this year at some point but looking at things currently i'm doubting that this card would be able to maintain steady clocks at that res.
Theres also the fact that some fins are slightly damaged which is really getting on my nerves even thinking about it. £700 card and whoever assembled it seemed to have a slippery screwdriver but because of where the damage is its very hard to see.
