Naive to what exactly? Using as much data as you require on an unlimited service, tethered or not? How exactly would that be naivety?
To believe that this would last forever.
It is drivel, in no way is it abuse. You really are being stupid.
It is absolutely NOT as simple as that.It's advertised as unlimited, so use as much as you want...
How's that hard to understand?
I bet most of the congestion comes from mobile users, not people tethering.
Is there any need for the condescending way you're responding?
3000 doesn't mean unlimited, ergo there's a contradiction.
I haven't used a 'mobile-optimised' site since I got my first smartphone in 2009.. they're horrible to use as soon as you have a touch screen and/or cursor (blackberry).
Exactly, but then anyone using 1TB of data a month needs their head examined (and their usage habbits)
Again, why?
Again, why?
There's no point in really replying to you anymore is there? You think it's possible (sensible, reasonable, rational) for someone to download or stream 1TB of data per month. Even MKV BD Rips of films swing in under 5GB these days, but you somehow think it's reasonable (or at least, not odd) for someone to execute 32Gb of data per day, or, to break it down, 12 hours of movies per day......![]()
No Glaucus.
Anyone with any expertise providing/supporting any sort of ICT/data service will tell you there is absolutely no such thing as unlimited.
You clearly don't have this expertise because you believe the word unlimited literally means unlimited.
You need to realise that there are calculations a bandwidth provider does in order to be able to safely call it "unlimited". If they calculate wrong then they will cease services.
The fact is mobile bandwidth is a shared bandwidth service, the same as any other shared data/bandwidth provider, as opposed to a dedicated or leased bandwidth provider.
The fact that you assume "in no way is it abuse" simply proves you don't understand how shared services work. You simply don't comprehend the reality of how shared services are pooled. All you care about is the marketing term of "unlimited" and trying to understand it literally instead of realistically.
Bandwidth doesn't just grow on trees. Companies advertise "unlimited" based on calculated/forecast averages. Even truly dedicated services have a limit, and you seem to think a shared service advertising unlimited is literally unlimited, which is laughable.
Has anyone yet clarified whether those who are getting the texts are out of contract and also downloading large amounts.
If so what's the problem? Three have honoured the contract and are now saying we don't like the level you use of our plan so will need to control your use. Seems reasonable to me.
Unlimited plans are unlikely to last, I hope three Continue to be ok with those on unlimited who stay reasonable but if they don't it's just a case of reviewing the best plans out there.
Then it shouldn't be called unlimited. There is nothing unreasonable about taking them at their literal word of unlimited.
Expertise is irrelevant. If there is a problem, they shouldn't say it's unlimited.
This is also irrelevant, they shouldn't call it unlimited if there is an issue in providing that.
This is also irrelevant. The problem lies in how companies name their services.
It's not an assumption, or a lack of understanding of how networking infrastructure works/
You don't need to know much to understand what unlimited means. As above, if it's not unlimited then they shouldn't call it unlimited. If there's a problem with the amount of data some people use, there is no justifiable reason to claim that the service is limited.
You are trying to make this significantly more complicated than it needs to be.
If the service wasn't advertised as unlimited, this discussion wouldn't be taking place. It is why Virgin Media had to stop claiming their service was unlimited whilst they throttled the connection speed when you went over a certain amount of data.
The technical workings don't matter, because you can get as technical as you want, but you'll never be able to argue that unlimited means anything but unlimited. Any issue with the amount used means it's not unlimited.
It really is, you're just trying to complicate it more than is necessary. This is one of those situations where keeping it simple leads to the correct conclusion, and that would be if they can't supply unlimited bandwidth, don't advertise it as such.
The same way a restaurant couldn't claim they had an all you can eat buffet if they limited you to 3 plates because their technical calculations show that the vast majority of people only had 2 plates.
teenage waffle
