Hope you enjoy it and anyone who does have issues with these we will swap out no hassle for the simple fact we've advertised them as such.
Unless of course they are trying to power them off a Tesco value junk PSU then they need to visit our PSU section and sub section Superflower.![]()
Superflower 1000w Plat, only the best
Nearly forgot to order an extra 6pin pcie!
That really is fantastic.
Weighing conflicting requirements against each other - the blower is good for compact systems but I am also looking for extremely low noise and the Titan cooler has a reputation for being the quietest blower, I assume it would be even more so on a 970.Why? If the 980 cooler is good enough for a 980, trust me it is more than good enough for a 970 and is performing as such.![]()
Your Superflower will have all the 6-pin connectors you need, they have enough for like 3-4 VGA in SLI.
£320 is painfully expensive for the 'wrong' choice of product. If it had the vapour chamber Titan cooler I might've been willing to chance it but for now I will wait and see more feedback.
The 980 cooler may be good, but under load maybe not be good enough (I can wear ear phones when gaming but that doesn't help anyone else in the house!) I think a Prolimatech MK-26 or Arctic Xtreme cooler would be quieter, although I'm not sure if they will improve much on some of the giant coolers already used on some of the cards.
The vapour chamber is because it needs to shift 100W+ more of heat! I doubt there will be a quieter 970 than this.
In a compact or low-airflow case, definitely. In a larger case with high airflow from large quiet fans, an open heatsink with a larger surface area is going to be able to run cooler and quieter. It's not a fair comparison, and the NVTTM radial fan is already pretty quiet, but I don't think it could claim to be the quietest.Remember MSI 970 and Asus Strix are quieter than this at idle as their fans do not even spin. But in actual gaming usage I can see this being the quietest card, especially in a small enclosure for sure.![]()
What constiutes a compact and low airflow case though exactly? I have an H440 on order, which isn't the BEST at cooling, but it's far from the worst either. Plus I plan to add some new high static pressure fans up front to help. I was always keen on getting something like the HOF or a ZOTAC Extreme card, but is my case that bad that it needs a reference card? I know for SLI it would be the best move, but for a single card set-up, I'm really not sure.In a compact or low-airflow case, definitely. In a larger case with high airflow from large quiet fans, an open heatsink with a larger surface area is going to be able to run cooler and quieter. It's not a fair comparison, and the NVTTM radial fan is already pretty quiet, but I don't think it could claim to be the quietest.
How long is a piece of string?What constiutes a compact and low airflow case though exactly?
What constiutes a compact and low airflow case though exactly? I have an H440 on order, which isn't the BEST at cooling, but it's far from the worst either. Plus I plan to add some new high static pressure fans up front to help. I was always keen on getting something like the HOF or a ZOTAC Extreme card, but is my case that bad that it needs a reference card? I know for SLI it would be the best move, but for a single card set-up, I'm really not sure.![]()
Hi! On overclockers it says you only have 9 cards left in stock. Is this true, because if it is, I will need to order one quickly!
Why do people buy reference cards? Is it because they want a smaller cooler to make SLI more viable?
